  • 3 Vote(s) - 3 Average
Which Oil filter wrench
I,v got a 2006 19D, its a pig to get the oil filter off, what type of wrench do you lads use, a link would be great, cheers.
hello vespa you ok,in the past i've always been lucky to undo them by hand,but in case i cant i've got the one with a length of bicycle chain attatched to a lever,the chain is wrapped around the filter and then pull on the lever to slacken the filter, hope this helps
Big Grin nice to be important,more important to be nice Wink
I,v got one of them mucker, but no matter how tight i have it it slips, i need something that fits it like a spanner maybe.
An old trick is to punch a screwdriver through and use the screwdriver as a lever.
http://www.amazon.com/Filter-Wrench-Plie...B0002SR56M
These type work quite well.
If you can't undo a filter by hand its too tight.
I only tighten by hand but can i hell it it off by hand.
Do you rub new oil on the seal and thread before you tighten?
How tight is tight?
Oil filters should be hand screwed on then once stopped by light hand screwing should be given another half a turn, only if it leaks should it be tightened a little more.
(10-10-2014, 09:20 PM)vespa 494 Wrote:  I,v got one of them mucker, but no matter how tight i have it it slips, i need something that fits it like a spanner maybe.
when you wrap the chain around the filter you do it in such a way that the end of the lever is positioned in one of the links and then pull on it when you pull on it the links dig into the filter, it should turn quite easily,and yes you do smear oil around the new seal and then tighten by hand,hope this helps,
Yes i smear oil on it, hand tighten it, it doesnt leak and i use the wrench in the right way, i always end up knocking a screw driver through it though.
as long as its off and replaced,yes i,ve used that method as well, but a very time ago,happy motoring!!
I use a chain wrench but no matter how many times I do the job I always get it the wrong way round first attempt Sad
4x 15" Alloys with tyres
Last Post: Guanajuato
Today 12:46 PM
Peugeot Partner 03 Van owner
Last Post: Art b
Today 09:19 AM
Titsup
Last Post: Art b
Today 09:17 AM
Last Post: Grizz
Today 07:50 AM
» Replies: 701
Language changed by itself!
Today 07:01 AM
Washer motor queryt
Last Post: Lighty
Yesterday 08:28 PM
Can i get away with 205/70r15
Yesterday 01:09 PM
How I installed an oil catch can in the 1.6HDi
Last Post: saskak
Yesterday 12:24 PM
valve clearances
Last Post: rublehousen
Yesterday 08:52 AM
brake light switch
16-04-2019 08:45 PM
