  • 3 Vote(s) - 3 Average
Knock knock
Hi All,
Just bought an 05 1.9d with 109000 on the clock.
Has had recent timing belt, sump and exhaust.
Was running fine for a week then the other day it started knocking and the engine warning light came on....
When I start the engine it knocks for a bit then clears. Followed shortly by the Engine light coming on. The engine idles smoothly.
Try and pull away and I have to over rev it to stop it from stalling. It also does a big puff of smoke and spat out some black water via exhaust.
There is also a bit of oil? Sitting on top of the manifold at the rear of the head. (I'm assuming rocker cover gasket)
I took it to my local garage and the guy says he can't get it to communicate with the diagnostic kit so I'll have to contact an auto electrician (sounds pricey)
So I guess I'm looking for a steer in the right direction. What to go for first.
Solenoid?
EGR?
ECU?
Beer?
Thanks in advance.
LB
Get the timing checked. I bet its also slower than sin. Topping out at about 60 on the flat and struggling to pull its own weight up hills?
Your local garage will have a snap on modus which wont connect to the injection system on this engine, get your self a u480
My injection pump was out of sync (retarded) after a cam belt change ,symptoms were major knock on start up , white smoke , lack of power. Now it pulls like a train ( for a dw8 - i have 2 of them now)
I expect a p0170 code.
How ever i think you also have other issues that im not sure on but getting a u480 and seeing what codes you get would be a start.
2015 Berlingo van for sale
Last Post: eddyale
Today 06:47 PM
Last Post: deejay_xb
Today 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
Today 01:48 PM
Unusual Braking Problem
Today 07:52 AM
valeo alternator CL15 rebuild
Today 07:49 AM
Yesterday 06:19 PM
oil Sump
Yesterday 06:18 PM
5 x 18" wheels suit B9
Last Post: raymondinio
Yesterday 04:34 PM
M59 1.4 Petrol question
14-03-2025 10:48 PM
14-03-2025 09:08 AM
