  • 1 Vote(s) - 4 Average
Near side read door central locking not working
I found out today that the nearside rear door on my 2005 2.0l Diesel Desire is not locking or unlocking with the central locking. The manual lock is working so I can secure the car from the inside but the central locking from the fob or internal button won't shift the lock on that door - it stays as you left it (locked or unlocked).
Is there anything simple that could have gone wrong or is this a costly fix? Thanks :-)
Citroen Berlingo 2.0 HDi Desire 2005
The actuator might have failed.
If you take the door panel off you should see the actuator working when you press the central locking button.
(16-10-2014, 10:23 PM)homeruk Wrote:  The actuator might have failed.
I had a similar problem with my 2005 Desire. It sometimes locked but never unlocked. I took off the door card (10 min) and gave everything a liberal spray with lube. I also cleaned up the contacts at the door frame and it works perfectly now. I must get round to doing the passenger side as well though it works fine so far!
Ok this is bizarre... I had the coolant temperature sensor changed on Thursday - and the door lock has now started working again.... I have no explanation! :-)
10-11-2026 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
