18-10-2014, 12:20 PM
Hi. i have a 2005 1.9 dw engine berlingo van. I have come to change the cam belt and according to the manuals the sprockets on the injecter pump and camshaft should have 3 bolts and a slotted sprocket. i have this set up on the injecter pump but on the camshaft it is a solid sprocket. Even with the belt tensioner removed there isnt enough slack on the belt to enable you to fit it. Has anyone else come across this problem before and can you give me any advice on how to fit the belt. Has the wronr camshaft sprocket been fitted ?
Thanks in advance for any help or answers that you can provide
