HELLO THERE
hi to all
first time poster and first time berlingo owner
i picked up a mk 1 03 plate 2.0 hdi van recently . as with most vans of this age there are a few minor niggles , nothing (i hope) major . it appears to be sound mechanically is ive just done a 600 mile round trip in it
the first issue was the driver elec window didnt work . the main problem here was the whole window regulator mechanism was missing ! a replacement was ordered from the bay and fitted yesterday but still no joy , after a bit of fault finding yesterday , it appeared to be a dry soldered joint on the relay board within the green box .re did the joint and that gave me 12v at the motor plug when the switch was activated , but the motor on the replacement still didnt work . so i assume this motor was faulty ???
next thing is . the heater / blower controls do not light up when the headlights are on , this was also removed yesterday , i found the bulbs in the unit , but im struggling to find replacement bulbs ?
any suggestions where to get these tiny bulbs from ?
the last thing is the key that came with it , i only got one but it doesnt activate the central locking remotely.
its not a massive issue as the key works in the door lock itself and opens all the doors , is it possible to check if the key fob actually works somehow ?
thanks in advance
stu
Howdy Stu and welcome to the forum.
Yesterday 12:02 PM
Berlingo 2026
Yesterday 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
