[Steering & Suspension] Rear axle.
Got the chance of a failed rear axle for Mk1, for coppers.  Is it worth a speculative purchase to be refurbished at leisure, just in case.
Mine has 96k on the clock. No signs of any problems with the rear axle yet.
Cheers,
Malcolm.
2001 1.9D Multispace.
Its normally the trailing arm bushes which fail.
Unless you have some serious pulling kit, refurbing an axle is beyond the scope of a home mechanic.
It might be worth it if you know of an engineering company that can replace the stubs for you cheaply then it becomes a viable option.
(21-10-2014, 02:53 PM)homeruk Wrote:  Its normally the trailing arm bushes which fail.
I thought as much. I do have options to have the work done, might just keep my fingers crossed.
Malcolm.
If you thought yours was likely to fail it would be worth getting as an exchange unit for a reconditioned one so you can do the job at your own pace.
(21-10-2014, 06:33 PM)ffrenchie Wrote:  If you thought yours was likely to fail it would be worth getting as an exchange unit for a reconditioned one so you can do the job at your own pace.
Mmmm. That's me thinking now.
I would say if you feel like want something to keep you busy during the winter, go to the car morgue and take one from there. Load it in the van and away you go. Preferably from a MK2 or something as newer as they got. From there it's about cleaning the rust, painting it, maybe throw some money on nice thick torsion bars, get new mounts for it and you are done
http://i428.photobucket.com/albums/qq3/B...AG0758.jpg
If you have a wheel bearing problem one day, or the torsion bars snap, or the mounts give in, you have a nice refurbished axle ready to go.
Last Post: stu76
Today 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
