Best way to lift/stiffen the rear end
Threads: 3
I,v just bought a lightweight caravan which i tow with my 2006 600kg 1.9D van, it sits abit low imo, whats the best, most cost effective way to lift it, bigger wheels, stiffer springs, spacers, or is there some other way, i can manage as is but it would be better slightly higher i think, cheers.
Threads: 29
Thanks Given: 67
20
If it's not hitting the bump stops I wouldn't worry about it just don't exceed the maximum nose weight for your van.
Threads: 3
(21-10-2014, 03:26 PM)vespa 494 Wrote: I,v just bought a lightweight caravan which i tow with my 2006 600kg 1.9D van, it sits abit low imo, whats the best, most cost effective way to lift it, bigger wheels, stiffer springs, spacers, or is there some other way, i can manage as is but it would be better slightly higher i think, cheers.
You must make sure noseweight is correct, guess it's only 50/70kg???? (but find out) ! so should still be level , make sure your tow ball is correct height, heavier springs will help to bring it level if you carry stuff in van too.
lrb
Threads: 3
(21-10-2014, 07:02 PM)landroverbob Wrote: (21-10-2014, 03:26 PM)vespa 494 Wrote: I,v just bought a lightweight caravan which i tow with my 2006 600kg 1.9D van, it sits abit low imo, whats the best, most cost effective way to lift it, bigger wheels, stiffer springs, spacers, or is there some other way, i can manage as is but it would be better slightly higher i think, cheers.
lrb
meant to say go on some caravan forums - help will be there. Years ago "airjackers" were good, I use airbags inside the rear springs of my disco kits about £120 but don't know if they do them for berlingos. get googling
Threads: 3
I,v had a look on you tube and iam not even sure the berlingo has rear springs, can you enlighten me.
Threads: 29
Thanks Given: 67
20
(22-10-2014, 07:51 AM)vespa 494 Wrote: I,v had a look on you tube and iam not even sure the berlingo has rear springs, can you enlighten me.
Berlingo uses torsion bars and dampers so airbags or spring assisters will be no use. You could look for coil over shock absorbers with assorted spring rates to help with the load but after market conversions are expensive.
Threads: 3
(22-10-2014, 10:23 AM)ffrenchie Wrote: (22-10-2014, 07:51 AM)vespa 494 Wrote: I,v had a look on you tube and iam not even sure the berlingo has rear springs, can you enlighten me.
is as above,........just looked at mine, no adjustment either. I guess the 800 van has stronger torsion bars, prob cheap to buy from a breakers but could be a knack to fitting them
lrb
Threads: 3
OK, well thanks for all your help, i think i,ll leave well alone.
Last Post: LucyLeBingo
Yesterday 02:42 PM
Yesterday 02:30 PM
Last Post: jw4821
Yesterday 12:53 PM
Coolant
Last Post: tomhick024
19-04-2026 06:18 PM
SOLVED: P20F6 fault
19-04-2026 08:28 AM
Leaking windscreen or aerial
15-04-2026 08:50 PM
