mk 1 green box
hi again all
after purchase , i found my drivers electric window mech totally missing
part sourced , fitted , fault found and got working , happy 2 or 3 days !
yesterday it stopped again completely .
this time im not hearing anything from the green box when the switch is activated . its not hte switch , ive swapped with the passenger side , i have 12v on pin 3 ......
green box is silent
any ideas ???
all sorted
the dry joint i 'repaired' the other day hadnt really took with the gas iron i was using
re soldered with a 240v soldering iron and all sorted
Good to hear it's sorted Stu, it's deflating when the electric leaks and pot luck to find it sometimes.
Last Post: Desdinova
Yesterday 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
