  • 2 Vote(s) - 1.5 Average
Rear Light Assembly
Hi Guys,
Does anyone know what the light is between the brake and indicator bulb on the passenger side.
It comes on very dull when the engine comes on and I have no idea what it is.
Also which bulb is the reverse light?
Cheers for your help.
Cookie
Isn't that the reverse light? I've no idea why it should light up though, unless there is a bad earth to the light cluster.
Btw, should there be a fog light on the near side?
Although the metal contacts are present in the bulbholder on the LHS cluster for a rear fog light, this for some reason is not wired in. Easy fix to fit a bulb 21 watt and run a wire down, across to the right hand cluster and join up with the RHS rear fog light. Did mine in this manner.
Cheers Guys, ill have a look at the earth.
Hi Guys,
Does anyone know what the name of the cable for fog lights on Citroen Berlingo M-space 2.0 HDI 2005 .
The cable is on the right hand side in the bumper.
Spot the Berlingo(s)
Today 12:20 AM
knocking from rear
Yesterday 04:59 PM
Last Post: Andhall
Yesterday 04:59 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 01:45 PM
» Replies: 18
An alternative to Diagbox - Topdon Artidiag 800B...
Last Post: swawp
Yesterday 09:41 AM
» Replies: 26
Berlingo 07 won't engage 2nd gear
Last Post: Kyleonsite
14-01-2025 08:28 PM
wipers
14-01-2025 06:17 PM
Last Post: xavier988
14-01-2025 10:23 AM
footwell fan
Last Post: de62
13-01-2025 10:13 PM
rear washer fires front?
Last Post: Brooky325
13-01-2025 10:00 PM
