02-11-2014, 11:40 AM
Greetings..
Here it is:
The attack on my first Berlingo issue.
When I bought the car, the mister said that there was a small failure in the left headlight, that maybe the wires had burned or something and he had bought the part and blah blah blah.
Anyways after I had "fixed" it the way he suggested, I replace the fuse for the left headlight (which shares it with the headlight washer pump), turn the car on and voilaa, the headlight works but hold on!!, if the headlight is on the washers are on, ALL THE TIME!!
I need to take fuse out in order to stop spraying.
Some clarifications:
Headlight washer means the liquid spray as for the windshield.
Windshield and rear window washers work normally
I was thinking it could be the relay for the washer pump.. but if somebody has any ideas, I'd like to hear them, thanks
Here it is:
1999 Berlingo 1.8i
