  • 1 Vote(s) - 5 Average
light in speedo housing
how do you change the lightbulbs in the speedo housing. i opend it up. and cant see any bulbs.    the left part og my speed indicator is in the dark. .
Will that white cover come off? If it does you should find black twist off bulb holders that use the standard capless wedge 286 dashbord bulbs. I'm guessing this as heater controls use these bulbs which I have to replace on mine.
I think you will find these are led / smd and are soldered in place and are a pain to do they do not fail that often so check your wire connection's first and for dry joint's
the withe cover can get off. but i think it would be difficult. because the 4 white circles seems to be connected to the indicators inside the housing. so if i take theese off i am worried that i break them.
there is only one wire harness going in to the housing on the back and it seemes ok
KPH display
Yesterday 11:39 AM
Jealousy, loyalty, the French.... and Starter Mo...
Last Post: Wakou
Yesterday 06:57 AM
UK residents take note!
Last Post: Eamon Devlin
13-07-2025 12:47 PM
Hello guys.
13-07-2025 10:04 AM
Touchscreen update
11-07-2025 01:41 PM
10-07-2025 10:09 PM
Adding aircon oil after component replacement
Last Post: Ian_99
10-07-2025 08:10 PM
Spare key programming ?
10-07-2025 02:37 PM
Rear electric window regulators
Last Post: phydaux
09-07-2025 10:27 PM
Problem Passenger Electic Window
Last Post: pavb2
09-07-2025 06:49 PM
