Threads: 7
Thanks Received: 4 in 4 posts
As the title, I need to get a cable through the bulkhead into the cab and wanted to know the best route for it. Thanks.Â
MarkÂ
2009 Citroen Berlingo 1.6hdi Lx van
1999 Peugeot 406 V6se coupe
Threads: 73
Thanks Received: 46 in 35 posts
5
i have the mesh type. and just slide the cable under it.
but if you have the solid bulkhead. you can open the side door and remove the plastic panel on the floor 3 torx i believe. and slide the cable behind the passenger seat and up through the hole where the plastic panel was. and route the cable where you want it , and replace the panel.
Threads: 48
Thanks Given: 4
20
Not certain about the Mk. II, but on my Mk. I I threaded it through the rubber seal around the bonnet release wire.
(Had to remove the switches and stuff above the fuse box to see, though)
Threads: 7
Thanks, it's for an alarm system after some scrote tried breaking in.
Mark
Thanks Received: 26 in 24 posts
Thanks Given: 52
12-11-2014, 10:58 AM
(This post was last modified: 12-11-2014, 10:59 AM by ATL_driver.)
(09-11-2014, 09:32 PM)Tikki Wrote: i have the mesh type. and just slide the cable under it.
think he meant from under bonnet to cab, not into the load bay
63 plate Berlingo working hard.....
