Hi, I have a few problems with my new '01 Multispace that I'd like some advice on.
My Mk1's windscreen wipers like to sit at half mast. they have the full range of motion and clear the screen well. There doesn't seem to be any looseness or play in the mechanism. But whenever the wipers come to rest, IE between intermittent strokes or when switched off, they move to the bottom of the windscreen as you'd expect and then move a few inches back up the windscreen: [Image: HhslEme.jpg]
Is there some kind of microswitch or position sensor that's up s*** creek or is this likely to be more complicated? I couldn't find anything with the forum search that sounded similar.
The accelerator pedal is really stiff and difficult to move smoothly. To me, that says that the linkage and/or cable needs lubricating. Assuming that the cable can be saved, what lubricant is recommended - engine oil?
The clutch is also a bit stiff and notchy, although to a lesser degree than the throttle. Again I'll have a go at lubing the cable.
The final (minor) annoyance is that the steering wheel sits pointing a few degrees clockwise when the wheels are pointing straight ahead. I know the tracking/alignment has been done in the past and I'd suspect that this was done with the steering wheel not centred, but is there a way to straighten the wheel without shelling out for another alignment? Maybe moving it one spline anticlockwise on the steering shaft? I'm prepared to live with it but if it can be sorted for pocket money I'd like to get it done.
EDIT: just thought of another question: before I pull out and bin the crappy aftermarket radio, will a modern headunit with ISO connectors plug straight in or is an adaptor needed?
Cheers
Cheers
Strip thread and back off 1/4 turn.
2001 (Mk1) Multispace Forte 1.9D
the radio went straight in and only needed the main and memory positive feeds swapping. I'll have a crack at doing the cables on the weekend. Ta
