  • 1 Vote(s) - 1 Average
DW8 engine/gearbox mounts
2006 DW8 engine - needs mounts i reckon...
engines moving like a maddy and at low revs lifting the clutch results in a vibration through the engine.
so there is a the top RHS mount - easy to get at.
there is one under the battery tray - the "gear box mount" - reasonably easy to get it.
Is there a third one - the "rear" mount - that is hard to get at - and doesnt get changed often ? - i recall looking into this in the past and somethign about having to take
im stuck in work atm so cant just take a gander Sad
any tips welcome.
ok got it - left - is the one you see on top of engine - its fine
right is under the battery tray - and is the gear box mount - its gubbed
and the rear is behind the engine to the left o the manifold. -its also fine.
Hi there, sorry for digging up the past here.
I'm having similar issues with my newly purchased Blingo. When you're checking the engine/gbox mounts, how do you tell if they are ok or gubbed visually.
Did you just check them visually or did you push/pull for movement?
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
