Threads: 69
Thanks Received: 22 in 22 posts
Thanks Given: 7
4
hi,you all ok,any answers on my query would be very much welcomed,driving around a roundabout today when another driver(i think his name was R.SOLE)cut right in front of me,so i slammed my hand down on the horn,since then my air bag warning light has been lit up on the dash,any suggestions, thanks in advance  MY MUCKER (Gwyn)
nice to be important,more important to be nice
my ride is a berlingo forte 1.9d 2003 model in pukey blue
Threads: 0
First thing I would check would be the earth behind the airbag,as the light came on after a hefty thump ,every time my airbag light has come on its been the wiring for the seatbelt pretensioners or the airbag earth,good luck.
Threads: 23
Thanks Given: 50
29
If it is the earth try the horn with ign off it should work turn ign on then try the horn if it does not work then it's the earth behind the air bag
Threads: 69
Thanks Given: 7
4
thanks Shammy and you Jed, i have been looking for visible means to remove horn push but cannot see any screws or such like,can you point me in the right direction please, thanks MY MUCKER
Threads: 0
Is it possible to hook up a scan tool to reset the air bag light?
Threads: 69
Thanks Given: 7
4
thank you very much Tomcat,not too sure about removing horn/air bag though,cant see any holes to push screwdriver through,will have a look when i got more light and a bit more time, thanks again
