  • 3 Vote(s) - 4 Average
Tyre Pressure Monitoring System.
On my New 2014 XTR model i have TPMS fitted. ( To be delivered December )
Can a second / spare set of wheels with TPMS valves fitted be coded to the car so in effect have 8 wheels that could be interchangeable without any individual re programming or not ???
I'd give the dealer a bell and ask. Probably the easiest answer.
Yes it can be done, National Tyres or similar may be cheaper then the main dealer .
http://www.national.co.uk/tpms-sensor-va...ement.aspx
Main Dealer price for TPMS sensors £86 each.
I believe they're a requirement on all new vehicles now. So would assume you just haven't spotted it yet. ( But i could be wrong )
There's a little yellowish / orange light that comes on briefly in the right had instrument face ( the speedo ) that looks like a flat tyre with an exclamation mark, that's it.
You can't just check by looking at the valve in the wheel as Citroen are using the 'Snap in rubber type valve' ( Obviously another cost saving exercise )
[-] The following 1 user says Thank You to Gollycrush for this post:
  • doofer
(16-01-2015, 05:32 PM)doofer Wrote:  Great - thanks for the info.  Presumably this only checks for dangerously low pressure then?  I think the dealer must have put about 30psi in when I collected it, as the tyre pump ran for ages to get them up to the required pressure when I inflated them for the first time.
On the contrary, you only need to have an imbalance of a couple of psi in a tyre to activate the dash light. ( some people find it annoying and have the system switched off !!!  but I'd rather know I've got a soft tyre )
  • doofer
I can't deny its a good system for letting you know of a slow puncture, but they are powered by internal, non-replaceable batteries so when they fail be prepared for expensive sensor replacements.
They power up on rotation of the wheel, so are mileage as well as time life expired.
The spare wheel (in my case at least) doesn't have the sensor which means that when I had the spare installed the alarm and light would keep activating.
Today 03:36 PM
Last Post: JPCoetzee
Today 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
