  • 2 Vote(s) - 3 Average
Rear lights not working!!!
My rear lights, and some interior lights, doesnâ€t always work!!! The normal light and license plate light does not work when the car is running, and some lights in the middle console. But everything else works just fine!!! HELP!
When you say that the lights don't always work do you mean they are intermittent - sometimes work, sometimes not? If they are out all the time then I'd check the fuses and try to get a code reader on the car to see if there are error messages. If it's truly intermittent then I'd have a look at the wiring, check earths.
Yes it is intermittent. No fault codes.
OK, then I'd check the wiring if you can get to it.
Found the problem and fixed it... There is something wrong with the wireing to the rear lights, so i just took a wire from the front lights and extended it to the one going to the back. Now i have lights Big Grin
Warranty on parts
Yesterday 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
02-08-2026 02:22 PM
Berlingo 2026
Last Post: xtimex
29-07-2026 03:34 AM
