30-11-2014, 02:48 PM
Hi,wonder if anyone can help I have a 2003 van with a1.4 petrol lpg engine which has blown the head gasket and warped the head .can anyone tell me which engine I can replace this with as someone has offered me a 1.4 saxo engine which is a 2001 .does anyone know the difference in the engine codes. thanks
Threads: 44
Thanks Received: 67 in 56 posts
Thanks Given: 9
10
See if you can get a TU5JP4 engine that can be found in many peugeos and citroens. Have a search on google and see what you think.
Threads: 48
Thanks Received: 272 in 229 posts
Thanks Given: 4
20
The TU5 is the 1.6i model. That may require a different gearbox?
This is a 2003 model, so it has a BSI. Does it need any updates if you get a different ECU?
(Someone else on the forum should knnow this)
With a TU3JP4 of the same age, you could reuse the ECU(check that they have the same model ECU first) and avoid problems.
