[Transmission] Clutch squeaking - replacement?
Hi, i've got an issue with my 2001 1.9D Bingo that I'd like your advice on. The clutch (?) squeaks at the bite point when I pull away in 1st or change to 2nd under any load. It's quite a distinctive 'PWEERP' noise from out front.
I'm wondering if this is an indication of a worn out clutch, or something like the release bearing is on its way out.
I'm comfortable working on and around the engine/gearbox, and I have my ex-mechanic father to help me, but I'm still waiting on my Haynes manual to turn up, and I want to make sure that changing the clutch on these things is possible with only a couple of trolley jacks, and some axle stands? I gather from searching around the forums that you have to remove the NS front wheel etc., but is a ramp or lift required to get the gearbox away from the engine?
Thanks Smile
Strip thread and back off 1/4 turn.
2001 (Mk1) Multispace Forte 1.9D
(03-12-2014, 08:47 PM)Tango91 Wrote:  Hi, i've got an issue with my 2001 1.9D Bingo that I'd like your advice on. The clutch (?) squeaks at the bite point when I pull away in 1st or change to 2nd under any load. It's quite a distinctive 'PWEERP' noise from out front.
Thanks Smile
From your description it may be the flywheel/input shaft bush is dry.
Yesterday 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
