  • 1 Vote(s) - 2 Average
Weird Behaviour at Full Lock?
Hi, I've noticed my Bingo does something weird while shunting it about in car parks, etc. Just before the the steering wheel gets to full lock on either side, there is an audible click from a solenoid somewhere, a single warning beep from the dash and the red 'battery discharging' idiot light is shown. When this happens, the interior blower motor shuts off.
Turn the wheel back a few degrees and everything returns to normal.
Is this supposed to happen? If so, why?  Confusedcratch:
Strip thread and back off 1/4 turn.
2001 (Mk1) Multispace Forte 1.9D
(14-12-2014, 10:08 PM)Tango91 Wrote:  Hi, I've noticed my Bingo does something weird while shunting it about in car parks, etc. Just before the the steering wheel gets to full lock on either side, there is an audible click from a solenoid somewhere, a single warning beep from the dash and the red 'battery discharging' idiot light is shown. When this happens, the interior blower motor shuts off.
Got the same car, mine does not do that.
Malcolm.
2001 1.9D Multispace.
Hi,
My guess is that on full lock you are putting more stress on the power steering pump/system and causing the engine to almost stall - hence the warning light. Try the same manauvres, keeping the engine revs up and see if it still does it. If that proves to "cure" it I think it's a fult within the Battery/Charging system or tick over speed, but I'm sure the more knowledgable will be along soon!
Griff
Landmark
Ex 1.4 Berlingo Multispace
Also, is your power steering fluid ok?
Landmark
Mine does all this. The belt on the engine squeals and stops turning which explains why everything stops, but I can't see anything that interferes with it!
Did you work it out?
Could be bottom pully sliping
Info display
Last Post: Stevie C
20-06-2025 09:59 PM
Brake problems again!
19-06-2025 08:47 PM
CITROEN VIRTUAL SERVICE MANUAL ALL MODELS
18-06-2025 05:34 PM
» Replies: 33
P0691 P0693 cooling fan circuit problem
18-06-2025 07:32 AM
Does My Van Have A Tracker ?
Last Post: Mark604
17-06-2025 03:01 PM
Last Post: Cumbrian
15-06-2025 09:02 PM
14-06-2025 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
