[Filters & Oil] Strange filter thing on top of engine
Question
Hi all,
I have a strange filter thing on the top of my engine (1.6HDI mk2 berlingo), I was wondering if you could let me know what it is please?
Hopefully the picture is attached to this.
Martin
hello Martin,cant help you sorry ,new to these cars .mine is a 1.9 mk 2 non turbo,anyway check to see where the braided pipe is coming from??could be some sort of breather ?
Big Grin nice to be important,more important to be nice Wink
my ride is a  berlingo forte 1.9d 2003 model in pukey blue  Huh
Crankcase breather?
Edit. not big enough after seeing it next to your hand.
Looks like a bleed point or some sort of pressure release?
Wouldn't think it was a filter/inlet.
Were does the other end go to ? look's like a non return valve of sort's
It is the vent to atmosphere from the vacuum solenoid that adjusts the boost on the variable vane turbo.
Hello JohnM welcome to the forum good to have you with us glad some know's where it goes to and from
oh ok cheers for that. Just out of interest - does it need changing every now and again?
thanks
As said it is not a filter, so no need to change it.
There is a little bit of foam inside the end, it should not block up unless your engine pukes a bit of oil from elsewhere as not a lot passes through it. If it does block it can cause the turbo to over boost and go into limp home mode.
Yet another ABS fault
Last Post: leftfootleashed
Yesterday 05:39 AM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
