  • 15 Vote(s) - 2.2 Average
Your opinion on this?
I have fitted a length of red led's on the inside edge of each rear light cluster,they are just small enough so they are visible from the rear,but unless they are switched on (wired into tail lights) you'd never know they were there.
[Image: TFQqA.jpg]
They sit just behind the edge of the tailgate.
The only thing is,I should have got a longer length so that they go right up to the top.
Your comments welcome.
2010 XTR in black with bells and whistles
[Image: 5A50i.jpg]
My only question, why?
(26-07-2011, 08:22 PM)steve valentine Wrote:  My only question, why?
a.
I find the tail lights aren't that good,the bulb has to shine through all those small holes and aren't very bright.
b.
I thought it may look nice,a cheap mod.:S
[Image: 5A50i.jpg]
Hi XTR,
I think they look really well and wouldn't mind doing it to my 2004 model but i just have a few of questions.
1- do they bend easily around the lights?
2- where did you buy them?
3- how have you fixed them to the lights?
Personally I like the idea. Anything one can do to attract attention that you are ahead of someone is good IMHO. You wouldn't believe the bone head drivers we have here.
(26-07-2011, 09:29 PM)BerlingoHDI Wrote:  Hi XTR,
They are very flexible,fully watertight,enclosed in a type of silicone.
They are fitted with 3M double sided tape.
They come in various lengths which you are able to cut to length (usually every three led's or so).
I actually bought them at a truckstop in Belgium,but they are available on e-bay and also at Hellfords and most car accessory shops.
I took the lamp unit off and simply wired into the loom with Scotchlocks the same as they do when wiring a light socket up for a towbar.
I'll try to take a couple more pics later today of them fitted to the rearlamp to show you.
Glad you liked them,and as 3rensho said,anything to make you more visible is a bonus,there really are some muppets on the road.Especially here in Belgium!:eek:
[Image: 5A50i.jpg]
[-] The following 1 user says Thank You to XTR for this post:
  • ron
Here is one of the strips which is simply stuck on the inside edge of the tail-light....
[Image: 7B1sn.jpg]
Make sure the cables are fitted so that water won't enter....
[Image: aUJOz.jpg]
(water won't run uphill) and they just tuck behind the lamp.
With the tailgate closed you can't see the strip.....
[Image: reljW.jpg]
And looking directly behind you can only just make it out....
[Image: vuP8i.jpg]
But switch on the sidelights,and hey presto......
[Image: GgeP3.jpg]
I have noticed that the LED's are side view type,but even with the normal SMD type's you should get much the same effect.
Hope this helps.
[Image: 5A50i.jpg]
Looks gr8 will they be ok on Mk2??
Multispace 1.9D Mystery Machine.
SCOTCHLOCKS!!!!!!!!!!!!!
Evil things, the only thing scotchlocks are good for is the bin! I cannot believe you have tainted your shiny bingo with scotchlocks. They will haunt you!
sent from a telephone that resembles a well known chocolate bar, dosen't taste like it though!
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.Confusedalut:
A centrally heated garage?
My, my, aren't these continentals sophisticated
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
