  • 3 Vote(s) - 3.33 Average
Berlingo towbar relay - live feed? where?
Hey folks,
Looking for someone to pull me out the ****.... I am trying to wire in my towbar relay I have done the rear wiring just need to provide a feed for it but I pulled apart the glovebox to get into the fuse box and it just looks so messy.. I'M LOST!
Can someone tell me what to look for or where I can wire it into?
Thanks,
Martin
First of all, do you have this plug behind the rear passenger side panel in the boot - the one marked No1
This is a permanent 'live' when a 40amp maxi fuse is put in to the fuse box in the engine compartment
[Image: livefeed.jpg]
Here is where the 40amp Maxi fuse goes in the engine compartment fuse box - you have to lift up the top section of the fuse box to reveal the Maxi Fuses underneath
[Image: fusebox.jpg]
If you don't have the cable and plug called No1 in the first picture, you can tap in to the glove compartment fuse box by using the spare plug shown below (ringed in red)
You will still need to add the 40amp Maxi Fuse to the engine compartment fuse box for this to become permanent live
[Image: glovefuse.jpg]
(24-12-2014, 07:55 PM)ntm1275 Wrote:  First of all, do you have this plug behind the rear passenger side panel in the boot - the one marked No1
I dont have the spare plug in the back i will try find the one in the glovebox tomorrow in the daylight. Thanks
It will have a single thick white cable going in to it
In the last picture, it appears that there is a small green one as well, but this goes somewhere else, it just looks like it is going to the same plug as the thick white one
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
26-02-2026 07:20 PM
