Berlingo enterprise L1 Van
I have a 62 Plate berling enterprise L1 van, I had the glovebox apart today and found a small black box with the words "Traffic master PLX" on top, this allegedly relates to a sat nav? but my van doesn't have sat nav just a permanent black cable for one?
Can anyone tell me what this is actually for?
Ta,
Martin
if you look on drivers side windscreen pillar you should have a small plug hole, my traffic master plugged in there and was stuck to dash board, I believe its a subscription service and can also be used to track your van , the black box is the master module and this is the screen thing http://www.ebay.co.uk/itm/Trafficmaster-...43d4d4be41
My van came with this Trafficmaster sat nav and a year's free subscription. I tried it once or twice, but it was such a useless system, that I carried on using my Tom Tom 1005 series sat nav.
It's not a secret that the OEM sat nav on the Berlingo is rather less than wonderful! Dodgy
Last Post: wbchevron
Today 07:34 AM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
