horn push
ello everyone, you all had a good xmas ??about my thread with the air bag warning light coming on caused by a heavy thump on the horn ??,i still cant find a way of getting the horn push off(lingo 03 multi)can anyone advise me please :brickwall:
Big Grin nice to be important,more important to be nice Wink
my ride is a  berlingo forte 1.9d 2003 model in pukey blue  Huh
Hi there if you have an airbag on the steering wheel you need to remove the cowling around the column and then on the back of the wheel you will see or more like feel 3 little holes. You need to put a small flat blade screwdriver in the hole and feel for a spring clip, gently prize the spring while easing up the airbag. Work around the clips until the airbag comes off. DO NOT FORCE IT. Be careful as the airbag has a ribbon cable attached to it. And before you start disconnect the battery and wait 20 minutes as you do not want the airbag going off in your face.
It is covered in the Haynes manual if you can beg borrow or steal one or nip down to your library.
ok Tomcat much obliged, thank you very much indeed
Coolant
Last Post: tomhick024
Yesterday 06:18 PM
SOLVED: P20F6 fault
Yesterday 08:28 AM
Leaking windscreen or aerial
15-04-2026 08:50 PM
