Egr cleaner?
Hello all. After a previous post decided to give the egr a clean. I have a 09 berlingo van hdi 1.6 90hp. Where do I spray the cleaner into? Could anyone send me a link to a guide or have a picture of which pipe I spray into?
Thanks in advance
I have never done this but reading others posts I think they remove the EGR from the engine first? Do a search for EGR that should turn something up for you.
(30-12-2014, 10:56 PM)Trevor Wrote:  I have never done this but reading others posts I think they remove the EGR from the engine first? Do a search for EGR that should turn something up for you.
If you have bought cleaner without removing the EGR :
https://www.youtube.com/watch?v=NaR1tb7s1us
https://www.youtube.com/watch?v=gOGjAQHVeCc
I would remove the EGR and clean it:
http://www.wikihow.com/Clean-Your-EGR-Valve
https://www.youtube.com/watch?v=TB1E9opb87Y
Ok thanks. Ive bought the cleaner and give it a go before I remove it and clean. Is the guy in this video https://www.youtube.com/watch?v=NaR1tb7s1us spraying it in the right place? Ive been told so many different things.
Thanks for your help.
(31-12-2014, 09:47 AM)Wking Wrote:  Ok thanks. Ive bought the cleaner and give it a go before I remove it and clean. Is the guy in this video https://www.youtube.com/watch?v=NaR1tb7s1us spraying it in the right place? Ive been told so many different things.
Yes, he removed the air filter and spray directly in intake pipe.
I don't know if you have MAF sensor. If yes than you have to spray after MAF.
Is this the air intake pipe? And am i spraying towards me? Thanks in advance.
[Image: imagejpg1-1.jpg]
Yes.
But I would do it this way. I don't know what stuff is EGR cleaner and I would be
spraying it after turbo. Maybe the cleaner would damage the turbo if you spray it before.
The best thing is to remove the EGR and clean. But you insist in cleaning it without removing!
Here is the pic that explains everything.
[-] The following 1 user says Thank You to brajomobil for this post:
  • ron
Yes.
Where is running into if I spray after the turbo? Considering taking it off to clean. Just wanted to see if the spray will make a difference.
[Image: imagejpg1-3.jpg]
(15-01-2015, 07:35 PM)king Wrote:  Where is running into if I spray after the turbo? Considering taking it off to clean. Just wanted to see if the spray will make a difference.
That is "inter cooler".
And maybe it will be better to spray after it.
So here is the pic of where to spray   Wink
Thanks. I've sprayed the cleaner and ran the car for 10k and it feels so much better on the throttle. Anti pollution warning light went out also. I'll give it a few weeks and report back.
Thanks for your help brajomobil
Yet another ABS fault
Yesterday 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
