What is this and why is it beeping when I indicate right?
This thing, located next to the right rear light unit in the jack storage area, started beeping today, every time the right side indicator lights flash.
It hasn't happened before now, and the bulbs are all fine. Any ideas?
[Image: jdhU9xt.jpg]
Strip thread and back off 1/4 turn.
2001 (Mk1) Multispace Forte 1.9D
this is a bleeper for a tow bar it should bleed when either side blinker is used (when the tow board is connected)
Thanks, any idea why it would suddenly start working? I haven't used the towbar.
(02-01-2015, 09:51 PM)Tango91 Wrote:  Thanks, any idea why it would suddenly start working? I haven't used the towbar.
It's getting an earth from somewhere on that side, it usually only earths from the trailer light plug. Disconnect it if you are not using it and it is annoying you but check the indicator still works after disconnection.
Last Post: ADarkDividedGem
Yesterday 08:06 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
