15-01-2015, 08:08 PM
Thanks for letting me join. I have a 2007 Belingo Multispace 1.6 hdi
Hi, im having trouble with a 2007 Belingo Multispace 1.6 hdi concerning brake bleeding. I have replace both wheel cylinders and bled system. The pedal went away so i replaced the master cylinder. There is now a pedal but it has too much travel for my liking. If i let off and pump again then the pedal is good. I have carried out normal bleeding, pressure bleeding, clamp off the back and bleed fronts and vice versa. bled master cylinder bled ABS pump engine on and off. Adjusted rear brakes, cleaned front pads etc but still brake pedal travel...some help would be great...cheers
It's too orangey for crow's It's just for me and my dog
