  • 32 Vote(s) - 2.63 Average
cooling fan
help
does anyone know which fuse and which fuse box for engine cooling fan on 03 berlingo 1.6 petrol
thanks in advance
These are the list of engine bay fuses for a new shape berlingo...if you want the exact wiring diagrams/fuses send me on your vin number.
Ron.
engine compartment fuse box (petrol)
fuses A supply matching
F1 10A +CC vehicle speed sensor - reverse lamp switch - clutch pedal information switch
F2 15A fuel gauge pump - canister purge electrovalve
F3 10A +CC ABS hydraulic unit - ESP ECU
F4 10A Engine management ECU - slow speed cooling fan relay - brake dual-function switch
F5 10A +BB free
F6 15A front fog lamps
F7 20A headlamp wash pump
F8 20A +BB Engine management ECU - slow speed cooling fan relay
F9 15A Left hand headlamp
F10 15A Right hand headlamp
F11 10A Left hand headlamp
F12 10A Right hand headlamp
F13 15A horn
F14 10A front/rear screen wash pump
F15 30A ignition coil - upstream oxygen sensor - Downstream oxygen sensor: not defined - Injector cylinder 1 - Injector cylinder 2 - Injector cylinder 3 - Injector cylinder 4
F16 30A free
F17 30A windscreen wiper motor
F18 40A Blower motor
MF1 20A - 80A + BB cooling fan relay
MF2 20A - 80A ABS hydraulic unit - ESP ECU
MF3 20A - 80A free
MF4 20A - 80A built-in systems interface
MF5 20A - 80A built-in systems interface
MF6 20A - 80A free
MF7 20A - 80A ignition switch
MF8 20A - 80A free
[Image: Berlingopsf1.jpg]
[-] The following 1 user says Thank You to Row for this post:
  • Lovebus
(28-07-2011, 07:48 PM)mister mechanic Wrote:  help
thanks in advance
Try here
http://www.berlingoforum.co.uk/showthread.php?tid=109
(28-07-2011, 09:42 PM)Hi. Vin number is: VF7GjNFUB931424158 cheer.Fuses seem okay, would you have any other ideas why I’m not getting power to the relay mounted in rad housing?cheersYou MRow Wrote:  These are the list of engine bay fuses for a new shape berlingo...if you want the exact wiring diagrams/fuses send me on your vin number.
Ron.
F5 10A +BB free
F13 15A horn
F16 30A free
MF3 20A - 80A free
MF6 20A - 80A free
MF8 20A - 80A free
Check the wiring back from the relay and I bet there’s a plug along the way and a load of corrosion... very doubtful the hidden maxifuse has blown, but not impossible, I’d be checking back along the way, ship the relaybout and see if you get voltage back at the relay with a multimeter and also an Earth aswell on the coil of the relay when fan is requested, I take it putting power directly down the relay base makes the fan switch on if there’s a power missing and you’ve checked the fans on, if not it may well have blown a fuse but it’s rare...
Yesterday 09:56 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
Last Post: stu76
18-08-2026 07:16 PM
