which speaker wire is which
Fitting new speakers ; but which wire is pos? The berlingo wiring is numbered 1 and 2.  No.2 wire is white and No.1 wire is a light brown colour but i can't see a pos or neg anywhere.
does it matter ?
Does matter to get speakers in phase, as long as brown wire and white wire go to the same corresponding tag on the speakers. Both speakers need to be pushing out or in at the same time otherwise there will be a downgrading in sound as one side tries to negate the other. I know this sounds daft but it is a well known fact among hi-fi and audio afficianados...
  • colin444
Andy is right.  The speakers must be in phase or the sound is not so good.  If they are out of phase that is basically the way that noise cancelling systems work.
[-] The following 2 users say Thank You to 3rensho for this post:
  • andy-womble, colin444
Ah well, you learn something new everyday. As long as my radio makes a noise apart from static I'm happy.
  • andy-womble
(19-01-2015, 05:29 AM)3rensho Wrote:  Andy is right.  The speakers must be in phase or the sound is not so good.  If they are out of phase that is basically the way that noise cancelling systems work.
Mind you, the noise cancelling might just negate some of the annoying rattles and noises of Berlingo ownership...... oooops !!! Exclamation Exclamation Tongue Tongue
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
