2 Factor Account Authentication
For those who want to ensure it is always them logging in to their account, we've introduced 2 Factor Authentication to the site.
In short, those who choose to Opt In will have to log in as normal, but will then need to provide a live code from another one of their registered devices in order to actually access their account.
More details can be found in the new Help Doc here: https://www.berlingoforum.com/misc.php?a...elp&hid=18
P.S - you can use 2 Factor Authentication for the majority of your other accounts (Facebook, Twitter, Amazon...)
[-] The following 1 user says Thank You to Andre for this post:
  • brajomobil
Thank you Andre!
Forum is running good Smile
[-] The following 1 user says Thank You to brajomobil for this post:
  • RolyG
It works great.
Great news, glad it's helping
Yes every one is coming back hoo ray good job well done Andre.
(20-01-2015, 12:16 AM)Andre Wrote:  For those who want to ensure it is always them logging in to their account, we've introduced 2 Factor Authentication to the site.
More details can be found in the new Help Doc here: http://www.berlingoforum.co.uk/misc.php?...elp&hid=18
I've updated the link in Andre's post and tested 2FA this morning. I think there may be a delay between setting 2FA and it being activated on an account as I had to try with Authy a few times before it worked. Once the code is entered it's not clear if you need to press the return key or press the 'check' button on the browser page, I pressed return and it worked eventually.
Here's the revised link:
  • Mike
(23-10-2021, 08:04 AM)cancunia Wrote:  I've updated the link in Andre's post and tested 2FA this morning. I think there may be a delay between setting 2FA and it being activated on an account as I had to try with Authy a few times before it worked. Once the code is entered it's not clear if you need to press the return key or press the 'check' button on the browser page, I pressed return and it worked eventually.
I've updated the first post, thanks.
Last Post: TGD
Yesterday 09:50 PM
Yesterday 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
