window washers .
Hi again , . We had a hard frost last week and the screen washer had frozen 50/50 mix .When I tried to operate the washers nothing worked . and only tried working washers at long intervals ,but no joy . Could I have done something to cause the problem . Water in tank is now thawed , when I lift the bonnet drips can be seen dripping from jets . Thanks for any info .  Car is 18 month old XTR auto 1600 . HB
You can damage the washer pump the impeller can break off, you will still hear it trying to pump but it will have a higher pitch sound. You may also get a slight dribble from the washer jets.
Are you sure the washer pipework is also thawed?
Positive the water is thawed , there is no noise from the pump at all ....HB
Ok sound like you have just blown a fuse.
  • ron
Yes i would go with the fuse being blown
Yes there is a 10 amp (red)fuse in the underbonnet box, can't remember the exact number .
Sorry to ask , but where is the fuse box located ,what does it look like?
(25-01-2015, 09:07 PM)henry sb Wrote:  Sorry to ask , but where is the fuse box located ,what does it look like?
It's under the bonnet on the right hand side by the battery under a black plastic cover  Smile you will find it in the Citroen hand book if you got one with the car that is
Update , took it to the dealer and they replaced it with a 15amp fuse . Everything OK now . But I think the jets are clogged up as they are not pointing on to the screen Have tried sticking pin in nozzle but just makes thing worse , I,ve only tried the passengers side . I see in another post that they can get gummed up .
(29-01-2015, 04:34 PM)henry sb Wrote:  Update , took it to the dealer and they replaced it with a 15amp fuse . Everything OK now . But I think the jets are clogged up as they are not pointing on to the screen Have tried sticking pin in nozzle but just makes thing worse , I,ve only tried the passengers side . I see in another post that they can get gummed up .
That's what happen's when you just put water in and no screen wash
New Berlingo Anyone????
Last Post: msw109
Yesterday 09:54 PM
multispace headliner
Last Post: big_chris88
Yesterday 09:46 PM
Torsion bar
Yesterday 09:17 PM
Berlingo----- Console
Last Post: Satellitemark
Yesterday 08:53 PM
Partner 3 seat (front) conversion
Last Post: dumdum
Yesterday 08:33 PM
How did the Berlingo get it's name ?
Last Post: Egg on Leggs
Yesterday 07:07 PM
» Replies: 15
Tyres and suspension
Last Post: labeline
Yesterday 04:35 PM
Aftermarket stereo wiring
Last Post: cancunia
Yesterday 01:37 PM
2007 1.6hdi desire
Last Post: Rob.nixon
Yesterday 10:32 AM
Seats
Last Post: kbracingdk
19-01-2019 08:57 PM
