Keyless update
Has anybody done a conversion to the keyless upgrade remote. If so I could do with some help please for a 2009 Berlingo van Huh
Hi nuvac and welcome to the forum. I frankly have no idea what you are referring to and, judging from the lack of responses no one else does either. Can you please elaborate a bit on what you want to do?
[-] The following 1 user says Thank You to 3rensho for this post:
  • nuvac
The locks on the Berlingo van 2009 are getting worn. I have lubricated them but they are not perfect. I have seen a lot of comments on the web about the problems. I have bought a Hawk keyless door open system in which you get a control box and two fobs which will allow you to open the van doors. I would be grateful to hear from anybody who has undertaken this upgrade as to the connections etc .
Hi and welcome to the forum ,
Does this Hawk system just lock and unlock the doors like a central locking system , or does it actually open the doors (or is that a silly question ?)
I fitted a hawk remote central locking kit to my van a few years back as I was getting fed up unlocking and not locking doors it is a very good system. I took my time and run all wires in sheathing and door motors fixed good and solid. The control box I fixed to the bulkhead up under the glove box then drilled through to the engine bay to take a live feed from the battery.
It cost 23.95 if I remember and it was great value and well made, I would not hesitate to recommend the hawk kit.
(29-01-2015, 09:46 PM)Tomcat3 Wrote:  I fitted a hawk remote central locking kit to my van a few years back as I was getting fed up unlocking and not locking doors it is a very good system. I took my time and run all wires in sheathing and door motors fixed good and solid. The control box I fixed to the bulkhead up under the glove box then drilled through to the engine bay to take a live feed from the battery.
Thanks tomcat3
I think your van was an early model and you fitted door the lock motors . This van has the key operated central locking system and I want to use the press button fob.
Ah see what you mean now. Yes mine was a basic van I fitted actuator motors and had a separate fob. I was like a pig in you know what it was luxury. The hawk kit was good.
(29-01-2015, 09:30 PM)brodfather11 Wrote:  Hi and welcome to the forum ,
No it doesn't open the doors it just locks or unlocks by press of a button, If you want the door opened for you then you  need to visit a top hotel.
Thank you for your welcome message.  Heart
[-] The following 1 user says Thank You to nuvac for this post:
  • RolyG
(30-01-2015, 06:10 PM)Tomcat3 Wrote:  Ah see what you mean now. Yes mine was a basic van I fitted actuator motors and had a separate fob. I was like a pig in you know what it was luxury. The hawk kit was good.
Yes I know I have often been up to my neck in it, (strong smelling stuff).
Thanks, have a good weekend. Shy
Last Post: ADarkDividedGem
Yesterday 08:06 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
