Clutch bite point.
Morning all! I've recently taken my 1.4 petrol berlingo in to the garage to have the gearbox sensor replaced. On picking it up both my wife and I have noticed the clutch bite point seems a lot lower than before it went it but the garage assures me they didn't touch the clutch workings! I understand the clutch is 'self' adjusting(?) so could it be the cable has simply worn and stretched and it's just a coincidence!? Still works fine just more 'immediate'. Any help much appreciated.
Hi & welcome.I believe there is a thread on self adjusting cables. It can happen if the cable is moved forcibly out of the way & usually means it's a bit worn.Do you have a Haynes manual? Good luck.
So.... The clutch pedal was half in and after a quick 'jiggle' it popped out!!! Job done!!! Obviously got stuck - nowt serious. Now - a virtual pint to the first person who can tell me how I can get the air bag light to go out on the dash!?! ?
Last Post: ADarkDividedGem
Yesterday 08:06 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
