Tyre Noise
Hi, I have a 64 plate XTR which has covered 1000 miles. I have noticed that the front tyres seem to be noisy when travelling at between 20 and 30 mph. They make a sort of wo wo wo wo wo noise on smooth roads. Apart from that they are fine.
Mine is an ETG6 model, so rides on 15" steel wheels.
Is this a berlingo trait?
2014 Berlingo Multispace 1.6 e-Hdi XTR ETG6
I'd just been driving a brand new ETG6 for all of last week (loaner car whilst mine was having some body work done). Didn't notice any unusual tyre sounds at any speed.
[-] The following 1 user says Thank You to 3rensho for this post:
  • jayjay2cv
What you describe is exactly the same as I experience on my 2010 VTR. It comes and goes depending on the road surface but it's always at around 30 mph. Both front tyres are Dunlop SP Sport Fastresponse (205/65 R15) which are about half worn (so much more than yours), and from what I've read on other forums these sorts of noises get louder as the tyre wears. I don't consider it too bothersome but I'll probably change the fronts for a different type sooner than I might otherwise.
[-] The following 1 user says Thank You to rm008 for this post:
  • jayjay2cv
650 miles on mine so far and no problem on factory fit Michelin.
I heard from my driving instructor its when the tyres are new and that's them singing, but that was on a truck.
I DO MISS MY BERLINGO Heart
[-] The following 1 user says Thank You to philip for this post:
  • jayjay2cv
Thanks, might try that Doofer as I haven't checked the tyres since collecting it last month. Failing that I'll just turn the radio up! Wink
They think you are going too fast and are telling you to whoa (like horses) Big Grin
(31-01-2015, 12:05 AM)jayjay2cv Wrote:  Hi, I have a 64 plate XTR which has covered 1000 miles. I have noticed that the front tyres seem to be noisy when travelling at between 20 and 30 mph. They make a sort of wo wo wo wo wo noise on smooth roads. Apart from that they are fine.
No...It's a tyre trait. Different tyres make differing levels of road noise. If you're happy with the performance of the tyres then
ignore it. If not do some research and buy a set of the best tyres with a low noise factor....could be costly!  Wink
  • jayjay2cv
My berlingo van has Avon ZT5's fitted allround and are very quiet indeed.
Mark
2009 Citroen Berlingo 1.6hdi Lx van
1999 Peugeot 406 V6se coupe
Hi jayjay
I have exactly the same thing on mine. I find that the tyre roar is high on rough roads but extra silent on smooth roads.
Must be designed for French autoroutes I think!
[-] The following 1 user says Thank You to scuderia_wilby for this post:
  • jayjay2cv
Yesterday 03:29 PM
Last Post: Triggermann
Yesterday 01:47 PM
15-07-2026 12:17 PM
Last Post: wbchevron
15-07-2026 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
