Changing idler pulleys?
There's a squeal coming from auxiliary belt I changed the power steering pump recently and it's still there I also put in an alternator from a scrap yard not too long ago so I think the bearings are gone in the alternator or the idler pulleys thing is I don't know if changing Idler pulleys is a big job any advice or help? 1.9D Berlingo 2000 model no AC
Tried to change my aux belt recently, awkward as hell more so when the belt was approx. 100 mm too small, and only bloody awkward when the right belt was used. Noticed the automatic adjuster /idler was slightly noisy but will keep an eye on it. Not noisy enough to justify the cost (£70.00 ?). The other idlers seemed easy to get at to change when engine was lowered.
How did you change it? Looking at the manual I'm supposed to use a special cranked bar to do it. Just wondered if anyone had a cunning technique that didn't involve buying an expensive tool.
On my 306 with the same DW8 engine, I had the automatic tensioner done by a garage (short on time) after it threw the belt off, so I probably wouldn't leave it.
Short while later I did the manual tensioner when I replaced the alternator. Just make sure you lock off the sprung tensioner with a bolt before taking the belt off. Both tensioners were original 14 years old, 100k miles.
Was it a hard job?
The sprung tensioner looked a bit of a pain, but the manual tensioner was straight forward.
Alternator was easy, just getting is out past AC pipes was tricky.
There was plenty of access once the wheel arch trim was off. This was on a 306 though, Berlingo might even have more space.
I only had a Haynes manual for reference.
Ive just had the same problem,Ive changed all the wheels and to no avail as the noise is coming from the alternator you can prove this by taking the belt off and running the engine,if the noise stops its the alternator[or the pump] but you say you changed yours. to take the belt off you need a long 15mm spanner and a home made tool, i used a flat piece of aluminium carpet strip 70 cm long, drill a hole at the end and put in a thin nut and bolt, the bolt protruding 2cm out from the nut.
Now push the tensioner back with the spanner and stick the bolt in the hole on the tensioner body, you have to wiggle it a bit to get it lined up, when its locked you can remove the belt.
Dont forget to draw a diagram of belt run and have fun.
[-] The following 2 users say Thank You to split rivet for this post:
  • ddb, Ol'Jeffers
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
