Comms Unit
I recently had an MOT and my Berlingo passed evrything except my Horn was working. The garage say that they will have to replace the comms unit. As a brand new comms unit is rather expensive I'd like to see if I can buy a second hand part. I have managed to find the part number 6242C2 (from Citroen) but this doesn't seem to match any of the part numbers of second hand parts on the internet. Could anybody help? I'm looking for a comms unit with automatic lights and windscreen wipers and radio controls as well.
Many thanks in advance.
I mistyped. My horn ISN'T WORKING.
Does it work with the ignition off ? The problem is usually a bad steering column earth not the comms unit.
Hi try Trusme on here he has done mine for me,
this is what he has put on here,
hello everyone i am the man from bradford on ebay repairing the comms units i thought i would have a look at the berlingo forum my name is Graeme (yes the ebay username and email address are correct as they are my partners) my mobile number is 07599587119 and i also have lexia and planet,
It is more than likely a poor earth under the airbag on the wheel. There are loads of threads on the forum about it.
It gets asked about once a week at least. There is a black earth that pushes into a square hole and over time it gets lose. You need to remove air bag cut connector off the wire and attach a ring connector, drill a small hole and screw the connector in place, job done. Just search the forum there are loads of guides on it. Be careful getting the airbag off. Its covered in the Haynes manual.
As Tomcat said i would look at that first
(03-02-2015, 05:35 PM)miapia221 Wrote:  Hi try Trusme on here he has done mine for me,
Hi miapia iv'e put your number and name in my Jed's  book of knowledge for a later date  Smile
Strut Top Mounts
Today 07:58 PM
Yesterday 09:30 PM
Yesterday 09:27 PM
Rear seat belt breakage
Yesterday 04:13 PM
removing front strut
13-09-2026 06:10 PM
12-09-2026 05:49 AM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
29-08-2026 08:39 PM
