  • 25 Vote(s) - 3.12 Average
Berlingo 2.0 hdi
Hi whats the best way to get more power out of my MK 2 Berlingo 2.0 Hdi? im thinking of a de-cat and im not sure if you can get uprated injectors to go in? many thanks.
remap or tuning chip box, prices from around 70 quid.
Personally I think the 2.0 has plenty of power, I regularly carry loads of around 1/2 tonne and have no problems at all keeping up with traffic on motorways.
(31-07-2011, 11:05 AM)steve valentine Wrote:  remap or tuning chip box, prices from around 70 quid.
I agree its a cracking van i was just wanting maybe a bit better acceleration.....are those tuning boxes any good? and ive seen decat pipes for 1.9 but not for 2.0 cheers
(31-07-2011, 10:52 AM)raptornexus Wrote:  Hi whats the best way to get more power out of my MK 2 Berlingo 2.0 Hdi?
If yours has got Siemens fuel injection system then forget it, can't do nowt with it. Think Bosch may be ok tho'
How can i tell which i have?
Should say so on fuel injection pump and the fuel filter housing is circular with lots of plastic type fins/lugs.
(31-07-2011, 05:45 PM)andy-womble Wrote:  Should say so on fuel injection pump and the fuel filter housing is circular with lots of plastic type fins/lugs.
Just had a look and it says Bosch...what injectors do i need
You will need one of those "Black-Box" plug-in units, think the injectors stay the same.
No idea on costs or where you get them from but have heard maybe e-bay...
Didn't realise that Steve Valentine has already mentioned this, see previous posting..
Ok Cheers
Tuning box - many available, they do make a difference, try to get one from a well known supplier. Or preferably...........................
Remap - Take advice, do your research and make sure you understand what you want and what you are buying. There are a couple of companies out there that come with a good reputation and also a couple of individuals who do good work too.
De cat - yes, get your garage or someone with a welder to cut it out and replace with a straight length of pipe. Does not affect MOT and makes a difference to the way it drives.
De EGR - if you have Bosch, then take it off, or blank it, or just disconnect the plug.
Don't think about injectors. They are very difficult to get hold of, expensive and difficult to calibrate properly
To go further you will need to intercool. Again do your research on what you want to achieve and how you are going to go about it.
There is a wealth of information out there and loads of people who will help with advice, experience etc. Problem is, very little is Berlingo specific and it is scattered all over the Web. Just take your time collating it.
Hope this gives you a starting point and an idea of what to do next. This is the route that I wanted to take, but having the Siemens system, I am unable.
If I can help further, let me know.
  • raptornexus
Last Post: andy@andymcm.com
Yesterday 01:47 PM
» Replies: 24
ASDA AdBlue 10 January 2026
Yesterday 09:06 AM
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
Blower fan
04-01-2026 09:58 AM
