OJ needs help.....
Question
'Kay guys I need a wiring harness diagram which shows all of the connector plugs for the external temperature sensor.
I've changed the sensor (thermistor) and the displayed temperature is all over the place as it was before the change. Occasionally it will display
the correct outside air temperature and suddenly the temperature  will begin to drop. OR the display will show minus 39 degrees
and very slowly climb to a realistic value. This sounds to me like one of the loom connectors is contaminated by corrosion.
Normally I would PM Rustscrat for this but he seems to have disappeared along with Addo so if anyone can help I would be eternally
grateful.
Hi OJ afraid all I can find is a note that says to make sure the connection wires close to the sensor are insulated after fitting, no use at all.
Have you tried Emailing Rustscrat, I think that can be done from this site?
All I can do Trevor is to PM him, which I have done.....how would I email him?
I don't know, all  I can see that some messages have :-
At the bottom....
Hi OL`jeffers try this http://www.berlingoforum.co.uk/user-1418.html
scroll to the bottom of his profile and click on the link to send a private message.
(08-02-2015, 08:41 AM)Tomcat3 Wrote:  Hi OL`jeffers try this http://www.berlingoforum.co.uk/user-1418.html
I don't think he comes on here much now, as his last visit was September.  You can't email him via the forum as he hasn't checked that option in his profile.
I fired off a PM, but as Mike says he hasn't been here for a while.
I also contacted Lighty via his website but I don't think he's read the message yet.
It's not that important but it's sort of annoying to get an Ice Warning in August!!
@TC3...tried that link but I don't have the required permission...
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
