  • 8 Vote(s) - 3.5 Average
lower arms?
I discovered today, that my berlingo has a split ball joint gaiter!!! it has the type that has a fixed ball joint which means replacing the whole arm. is it possible to replace the old arm with a arm which has a removable ball joint?
I think someone did this the other day to their Berl, here's a quick bump so you two can find each other.
(31-07-2011, 10:17 PM)Daivanman Wrote:  I discovered today, that my berlingo has a split ball joint gaiter!!! it has the type that has a fixed ball joint which means replacing the whole arm. is it possible to replace the old arm with a arm which has a removable ball joint?
Yes you can get wishbones with removable balljoints BUT by the time you come to replace the balljoint again it would probably want bushes in the rest of the wishbone. I cant see the point of just replacing the balljoint as you can buy wishbones for less than £25 a side. To buy a balljoint and the 2 bushes on their own will cost you most of that. I replaced track rod ends, drop links and wishbones for less than £80. I appreciate you have to have the money to do it but just do the let and then you know its all good for a while! Confusedalut:
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.Confusedalut:
ive decided to go with what you say bud, bought two arms, also going to change both springs and anti roll bar links, cant seem to find a top mount kit for mk 2 belingo's though!!! anyone know where i can get them?
Where have you got the wishbones from and what have you paid
I got them off ebay! the dealer says there quality parts and i paid 60 with delivery for them, eurocar parts want 60 for 0ne arm, which usually comes in a blank cardboard box .....
Got mine off ebay too, said to be top quality, but the ball joints are shagged again after a little over a year
the ones i recieved today are trupart arms, my cuz stocks them in his parts place and said that they were ok and the price was good to, but tbh the balljoint gaiters look easy to tear!!! we shall see...
[-] The following 1 user says Thank You to Daivanman for this post:
  • 800HDI
Diagbox 9.91 free download
Last Post: Slowmo
Yesterday 06:29 PM
Last Post: Slowmo
Yesterday 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
