15-02-2015, 05:37 PM
Hi all
I have factory fitted parking sensors on my 2005 berlingo van but today they have developed a fault, when you select reverse the usual beep occurs but then a longer beep follows and the sensors dont detect what you are reversing into.
Any help is appreciated
Adam
Adam
it could be switch on the gearbox have you checked to see if the reversing light come's on and stay on when you put it into reverse and check for loose wire on the switch
