  • 1 Vote(s) - 2 Average
with regards to cleaning out my combustion chaimber
Information
Must i strip down the whole head in my 19d berlingo or is there some way to avoid this and just flush it thru as i just cleaned and re asembled rocker cover and fuel filter filter due to t
ar build up any usefull hints tips and diagrams woulbe muapriciatedd
To do it properly yes, you need to take the head off.
What makes you think it needs doing anyway?
[-] The following 1 user says Thank You to mikep1973 for this post:
  • ryansm02
I got it going after i cleaned it it ran for about 5 miles and was smoking alot and wont start again
Will need to take the cover off and take as much of the crap that the car has built up again and se where it goes from there
(18-02-2015, 07:26 PM)ryansm02 Wrote:  Must i strip down the whole head in my 19d berlingo or is there some way to avoid this and just flush it thru as i just cleaned and re asembled rocker cover and fuel filter filter due to t
Sorry this wasnt posted before.Its probably too little to late but i came across a very interesting set of videos on utube recently ,well worth a look.If you can get utube up on your screen, and in the search box type in "decoke with water" you will find several videos on this very subject.I wont say any more ,just make sure you take a look.Its an eye opener,and will save you hours of work.!!
DPF Filter "do I really need it"
Today 01:01 PM
First cold startup metallic noise.
Today 11:38 AM
Water inside door
Last Post: Buki
11-11-2024 10:07 PM
Berlingo MK3 (K9) seats
Last Post: Vincent Rooke
11-11-2024 10:21 AM
New Van - 2017 B9 BlueHDi build
Last Post: sciteacher
10-11-2024 04:35 PM
» Replies: 39
2011 B9 radio change possibility
09-11-2024 10:47 AM
Headlight removal
08-11-2024 04:45 PM
Cold Start Valve
Last Post: Jehu40
08-11-2024 03:29 PM
Last Post: oldbury863
07-11-2024 07:47 PM
» Replies: 31
M49 Brake caliper carrier
07-11-2024 07:34 PM
