21-02-2015, 04:56 PM
Hello all ....
Glad I found this forum.
1.I have a 2006/7 Bingo that has developed an issue with the gears. Seems like they are misaligned from the gear stick (?) and have to be 'tickled' into place. Local dealer has checked the clutch / gears (when warm) and said it seems OK (!). I confess to not knowing anything much about motors and it is getting a bit late in the day for learning.
Was planning, with the help of a friendly mechanic, to start by changing the gearbox oil, (75/80 I think) then check operation before considering if the rods / bushes are worn. Then consider replacing them perhaps ? Dealer said that the gearbox oil is sealed so it couldn't be an issue. Doesn't seem to be any leaks that I can see.
[i Have lubricated the rods and this did seem to make gear changing easier. The car picks up a deal of mud from the roads due to the local farmers up here./i]
2. Partial failure in the power steering. Steering tightens up drastically as you go around roundabouts. No issues with small steering movements. Levels are good. From reading, (and I could be wrong, air locks would purge themselves with use of the steering ?). Seems like a new / recon/ pump is required ?
Any advice gratefully received.
