25-02-2015, 10:18 AM
Have a problem with '97 M49 diesel:
Van won't start as when ignition switch is rotated to the 'start' position, nothing happens other than the ignition light extinguishing. Have tested starter off the vehicle and it is fine. (have not yet tested feed to starter solenoid).
Can someone provide the wiring at the ignition switch barrel. I haven't the time to sort this if there is a short in the ignition/starter harness, so wish to bypass/replace that wiring but ... need the ignition switch wiring colours !!
Many thanks in anticipation of response.
