Threads: 3
Just got a 2003 Berlingo and the rear wiper doesn't do a full sweep of the rear screen. It goes about a 1/4 of the way and then stops. About 10 secs later it will move another 1/4 and so on. The wash/wipe position works fine with several full sweeps back & forth before parking.
Any ideas what has happened and what the fix is?
Richard
Threads: 27
Thanks Given: 20
13
I expect the mechanism needs a clean and lubricate. Sometimes the spindle through the bodywork gets tight due to corrosion. Take off the internal panel to expose the motor.
Threads: 3
I'll take a look, but as I said on wash/wipe it works fine.
Richard
Threads: 3
Anyone with any idea on what could be the problem?
Threads: 20
Thanks Given: 2,126
18
All I can suggest is bad connection somewhere.Check to plug on the motor with meter/test lamp.It may be the stop contact in the motor.just throwing my thoughts at you.Good luck.
Strawberry flavoured windows
