03-08-2011, 03:44 PM
Hi All, This is a desperate plea for help, the story is long and involved so please bear with me.
I own a 55 plate Berlingo 1.9d which I believe has the dw8 style engine, im no mechanic but its the engine that has a green cool&temp sensor with another blue sensor next to it.
I shall now begin, the van will simply not turn over off the key, we have replaced the battery as that was shot to bits, we gave the van to a garage that said the fault was down to the fuel pump (the lucas type). after install new fuel pump, the issue is exactly the same, the engine will start when u spray brake cleaner into the inlet manifold. once the engine is warm it will intermittently continue to tick over and will start off the key when hot ! but as soon as you put any load on the engine. the minute u lift off the throtte it cuts dead !
We have also recently had an auto electrician look at the data, and came up with a fault that the ecu was not matched to the advance solenoid on the fuel pump, we paired them via a program and the fault still exists.
when running tests apparently the advance solenoid was asking for 4% fuel but was producing 20% which is obviously flooding the engine and explains why it wont start.
the auto electrican seems to think there may be a wiring fault from ecu to advance solenoid.
has anybody had a simular issue that can help as this is really getting me down now
i really want to use my van again.
please help guy's
much appreciated
Tom[/size][/font]
please help guy's
much appreciated
Tom[/size][/font]
