08 1.6Hdi thermostat.
Is there any how to's for this? my van doesn't get up to temperature. And I cant see to find nothing on the good ole google. Thanks guys!
(03-03-2015, 09:32 PM)Mehmet Salahi Mehmet Wrote:  Is there any how to's for this? my van doesn't get up to temperature. And I cant see to find nothing on the good ole google. Thanks guys!
They cost £30 and are part of the plastic housing on the gearbox end of the cylinder head. Have you checked the water level first? No water = no heater. The heater matrix are notorious for leaking on the Berlingo.
My water levels are all fine. My temp gauge doesn't get higher then 70ish and when I put heaters on its warm/hotish air. But not what it should be. Only got the van yesterday! I don't even no what side the gearbox end is. Big Grin haha
Ho did you get on with this?
I think I need to do mine. Its taking ages to warm up and rarely gets up near 90. Just wondering how difficult it is to get to it, get it off, bleed all the air out afterwards etc.
Thank you
(28-10-2015, 11:48 PM)badlydressed Wrote:  Ho did you get on with this?
Thank you
Hi it was probably the easiest thermostat I've ever changed although I still dont get up to 90. Unless Im stuck in traffic . Bleeding it is also very simple considering you don't have any other problems.
Last Post: chrisl
Yesterday 06:48 PM
Cruise control retrofit
Yesterday 05:22 PM
tyre pressure monitoring system (TPMS)
10-12-2025 07:50 AM
Wishbone Lower Control Arms Questions
09-12-2025 07:19 PM
Anti Pollution fault warning
Last Post: labeline
08-12-2025 01:00 PM
Wire through bulkhead
Last Post: Jakejjt
07-12-2025 05:25 PM
Loose tailgate spoiler
07-12-2025 04:52 PM
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
