Thanks Received: 1 in 1 posts
Hey people new to the forum and berlingo ownership .
From i bought the van been having a problem with the blower .
It only works on setting 4 , now i followed the instructions and changed it out but prob still there
Ive hooked my multi meter up to the plug going into the blower and setting 1-3 im only getting 1.10volts and on setting 4 im getting 14volts , does this mean my switch is nackered .
Cheers people
Cheers can anyone tell me how i can access this up in the back of the dash and how do u remove the glove box ?? To get in there
Thanks Given: 188
23
If its a mk2 you have to get on your knees and look under the glove box, there is 3 possibly 4 round plastic clips to remove. fold down the carpet panel then look up under the dash and you will see the blower motor. The resistor pack is visible and just unclips to remove. Its sounds very much like the resistor pack has gone make sure you check which part you have before buying as there are a few different versions available.
Are we there yet?????
Cheers people found it up under the dash and got a new one from citroen for a cool £30 and all sorted .
Thanks again for all the help
