Hard Wire For Dashcam with permanent feed
Hi everyone, thanks in advance for any info that may help me with the above subject.
I have a 2014 L1 rhd and i am looking to hard wire it into the "in cab" fuse box on a permanent feed.
I will be using the cameras supplied cigarette lighter socket male charger (in line) connected to an extra female adapter which i would like to fuse tap and when both are connected/joined will be tucked away behind glove box.
Has anyone done this or has anyone got any ideas as to where i can tap into a permanent feed for the extra female as i would like the camera to roll continuously without having to use the obvious dash cigarette lighter "in view" configuration
Your influence like your shadow extends where you may never be!
There are piggyback fuses on ebay which you can plug into the fuse box and it gives a fused feed for you camera.
http://www.ebay.co.uk/itm/Add-A-Circuit-...27f18f4d0f
  • whitebus
Thanks for your reply Brodfather, i am intending to use a piggyback but ideally i need to know a suitable slot in the fuse box that has a permanent feed. Most of the fuses are the micro type and almost impossible to get at using the supplied tweezers. I have got a norm sized piggy back holder, i am not sure if they do one for a micro fuse.
I am trying to avoid going down the "fuse box under the bonnet" route.
Cheers!
They do do mini piggyback fuse holders, try under the steering wheel fuse box  if  the new models  have a fuse box there,   its handy and if its like mine there are choices for a ignition control feed or permanent live feed. Your handbook will give you a good idea of which fuse to use.
 (doubt if its like mine 01 reg 1.9d )  Huh
(07-03-2015, 10:53 PM)brodfather11 Wrote:  They do do mini piggyback fuse holders, try under the steering wheel fuse box  if  the new models  have a fuse box there,   its handy and if its like mine there are choices for a ignition control feed or permanent live feed. Your handbook will give you a good idea of which fuse to use.
I'll have a better look in the cab today depending what the wind is doing, nearly lost my drivers door from the hinges yesterday!
There is very little room for manoeuvre in passenger side fusebox, it's bad enough trying getting the meter probes in.
Not sure if the smaller fuses are mini or micro i will pull one and measure size as your right they sell piggybacks for standard mini and micro on Ebay so thanks!
I'll see how i get on and let you know!
I'll be doing this my self soon. My plan is to take power from the 12v lighter circuit with an inline fuse for extra protection.
I've done the hard wire setup and it works but I've got it on an ignition controlled feed. My camera needs a 5 volt feed via a usb cable and so I've rigged up a 5volt feed for it.
The only problem is the interference on the radio , if in a bad reception area its terrible,  it may be the Chinese 12v to 5v voltage droppers that are causing it , unfortunately I cant find a cheap substitute. Tried three different ones but no improvement , I've even tried a ferrite filter on the cable , it helps a little  but not much. Huh
So if your setup works with no interference let me know please. Big Grin
Thanks doofer
The interference does go away when running on internal battery, so I don't think its the camera (cheap Chinese thing) but that's not much good as it does not have a big capacity battery.
It is quite near the aerial and the further from it away I put it the better it gets when hardwired powered though I never really get a good radio reception with it on. There is a little which is acceptable with the dangly wire powering it but the idea of hardwiring it in was to do away with the dangly wires.  May have to go back to it.   Dodgy
There could have been a clue when the packaging on one of the Chinese voltage dropper said it did not conform to the EC standards. Exclamation
Hi doofer ,
                I do appreciate your suggestions, thank you. Big Grin
It seems nobody else seems to know anything about these type of problems , yours are the best solution so far.
In a good reception area the radio and camera combination works fine, with or without the dangly adaptor but when I go into a poor reception area the radio suffers really badly when the camera is plugged into the hardwire arrangement. When the dangly thing is used its not perfect, just a slight background hiss but acceptable . The hardwire arrangement has got to be disconnected altogether at the fuse box just to be able to listen to the radio.
My next move will be to take a feed directly from the battery rather than the fuse box to see if its something causing interfering in the fuse box which is near the ecu/bsi and may be being picked up by the Chinese 12-5volt dropper which sits just above the fuse box.
There are dedicated power 12v-5volt dashcam supply boxes (@£5 or so ) so will try one of those.
They cut off supply if battery voltage falls below 11.6 volts so as not to flatten the battery.
There are a lot of hills and poor reception areas around me and no dab and minimal digital tv.
(10-03-2015, 02:00 PM)doofer Wrote:
(08-03-2015, 10:01 AM)RadgieGadgie Wrote:  There is very little room for manoeuvre in passenger side fusebox, it's bad enough trying getting the meter probes in.
If you could let us know what size piggy back is needed that would be much appreciated, as I'm embarking on the same job.
I think I'm going to use an ignition live supply rather than a permanent live, at first anyway.  This way it will switch on and off automatically.  Although I know some can now sense the voltage change of the permanent live supply, so you get the auto on/off and parking guard too.
I'm looking at this one...
http://www.ebay.co.uk/itm/271762547330
And I understand the parking guard bracket may be available sometime now-ish.  This contains the voltage sensor to enable always-on filming.  With the standard bracket, I believe it can still do parking guard but only after a physical jolt and then until its own battery dies.  My understanding's fairly limited though - I'll order it and see what it does.
If I decide to swap to permanent live then it's just a matter of swapping to a different fuse slot.
Where's the best place to take a 0V from?
Hi, yes i will let you know as soon as get round to sussing it out, unless you have already sorted it by then.
I am putting G1WH camera in, the quality is amazing, but please do your homework as there are some fakes out there apparently. I would give you the link to where i got mine from but i cant find it in my ebay purchase history!!
Below is a link to the G1WH it has the constant roll over record as a feature for when parked and G-sensor.
I downloaded some footage for the police after an accident and they were well impressed with the quality!
http://www.ebay.co.uk/itm/G1WH-1080P-201...1454671153?
Cheers!
Warranty on parts
Yesterday 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
02-08-2026 02:22 PM
Berlingo 2026
Last Post: xtimex
29-07-2026 03:34 AM
