Oil change time
Hello chaps!
What size / type tools are required for the sump drain plug and the filter cover on a DV6 (2012 1.6 75)?
(11-03-2015, 02:58 PM)evdama Wrote:  Hello chaps!
you need 27 mm socket for the filter cover and a 21 mm for the sump plug - good luck be sure to fit the new filter correctly!
[-] The following 1 user says Thank You to bernie heerey for this post:
  • evdama
Thanks Bernie
Any idea what the torque-ness should be on them
On my oil filter housing cap it says 25nm. Not sure about the drain plug though.
[-] The following 1 user says Thank You to 3rensho for this post:
  • evdama
Sump plug, I've got down 25Nm / 19 lbf-ft in my notes.
[-] The following 1 user says Thank You to jamesg for this post:
  • evdama
Thanks both.
2 year service not due till this time next year,but I wouldnt leave oil changes that long not- even on my worst enemies lawnmower.
Is it a copper seal on the sump plug?
Yes, copper washer, but can't remember if it's a crush washer. I measured the one that came off and got a load more from ebay. Oil change is easy on this really, sump guard probably takes me the longest step.
Just a normal copper washer - reuse
Big Grin
(15-03-2015, 06:44 PM)polar Wrote:  Just a normal copper washer - reuse
Not taking chances with any aspect of oil change!
Thanks for info everyone.
All went well,filter was the only element [Image: biggrin.png] of uncertanty but didnt take long to figure out.Not the best design in the world though.
Copper washer was too badly distorted to reuse and a new one was only 20p (20mmx10mmx2mm)
 Filter (1109AY) was from the local main dealer at £16 -saw them going for under £7 on ebay-one to remember next time.
Oil was Total Quartz Ineo 5w30 Peugeot/Citroen from Nielsons -way cheaper than the £9/litre the dealer charged me last service.
It was the vehicles first MOT -service not due until next year so I used the downtime for an oil change.
Only 4000 miles done since the last service so it hadnt become too dirty.
The engine sounds quieter,and the oil pressure light goes out quicker,engine feels perkier.
All this could be just in my head but Ive gained 3mpg off my fuel consumption-that cant be.
I do believe that the dealer charged me for decent oil but filled up from the barrel of general purpose muck.
I'm glad it went well it keeps the blood pressure down. Wink
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
